Feature request: Replace Symbol in Device Editor
scott
Message 1 of 8
scott
It would be helpful to have a Replace option for the Symbol in a Device, similar to the Replace option for the Package.  I have a lot of duplicate symbols, an artifact of dragging Devices from a library in Control Panel into an Open library.  When multiple Devices reference the same Symbol, dragging and dropping them into a new library creates duplicate Symbols, and I want to clean this up.  An example: I now have symbols called RES, RES-1, RES-2, RES-3, etc., which are all the same.
Scott
Replies (7)
Message 2 of 8
jorge_garcia
Hi @scott,
I hope you're doing well. In this scenario I think your are better off cleaning up the libraries. Long term the reduntant symbols will create confusion. The EAGLE library Table of contents view does a good job of telling you what devices use what symbol so you can remove consolidate the devices to just use one resistor symbol.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
Message 3 of 8
scott
Hi Jorge,
Indeed, I want to clean this up, and my requested feature would make it much easier.  Currently, here are the steps I have to take:
- In the Table of Contents, click on one of the duplicate Symbols to see which Device is associated with it.
- Open the Device, delete the Symbol and add the correct Symbol.
- For every Package in the Device, reconnect the pins.
- Go back to the Table of Contents and remove the duplicate Symbol.
- Rinse and repeat.
In some libraries I have literally dozens of these duplicate Symbols; in one library there are 75 of them!  It would take me hours to clean them all up using the above workflow.
Scott
Message 4 of 8
jorge_garcia
Hi Scott,
Thanks for the clarification, for some reason I thought you were requesting this for the board and schematic editors. I'll make an enhancement request for this. That's what I get for not paying attention to the thread title.
Best Regards,
Jorge Garcia
Message 5 of 8
Any update on if this feature is getting traction?  I too would find it helpful.
Message 6 of 8
davidspady
I agree with the OP.  It would also be nice to be able to import something like a capacitor into a library without it creating a new C-1, C-2, C-3 ... symbol that then has to be changed back to just C.  I've tried to edit the library .lbr file directly, but somehow the changes don't stick after Library->Create new Version.
Message 7 of 8
mooreQAWLU
Community Visitor
Community Visitor
I agree. This has been a problem for years. As well as the library's buggy search feature. It's time for the library's UI to get a makeover.
Message 8 of 8
mooreQAWLU
Community Visitor
Community Visitor
Any progress on this?
The library manager is extremely difficult to work with. I currently have multiple devices, each pointing to their own symbol, and their own footprint and each footprint points to its own 3d model. I only need one resistor/capacitor/inductor/etc symbol, one 0402/0603/0805/etc footprint and one 0402/0603/0805/etc 3d model.
Is there really no easy way to clean this up?
