I just downloaded EAGLE 8. I'm on Windows 7. I restarted my computer like the program asked for after installation.
Each time I try to open the program, I get this error.
What do I do?
Solved by jorge_garcia2. Go to Solution.
Hi Lancebototo,
We are really sorry for this inconvenience, can you let me know if you computer does have internet access after the reboot? Are you behind any corporate firewall?
Best Regards,
Ed
Hi lancebantoto,
The developer continue to working on it, hope to get some resolution soon. can you please provide you the following details:
- Exact linux version (run cat /etc/issue and uname -a)
- Info about the network configuration (switching networks/interfaces???)
Please be as detailed as possible.
Best Regards,
Ed
Like I said earlier I'm on Windows 7.
Network configurations:
- IPv4 Connectivity: Internet
- Media state:Enabled
- Security type: WPA2- Enterprise
What information are you referring to?
I'm having the same problem. Is there a prior version that we can download while waiting for this issue to get fixed?
Eric
Except if the original poster subscribed, the subscription won't be valid for v7 and they will be stuck with Freeware functionality.
James.
How can I downlaload the previous version in English ? I download from the site given by you. but langauage is in german.
No still same problem. I download the software and then try to install it. but it automatically choose the german langauge . I need the software in english version.
Thank You
Dear Support,
I installed eagle 8 and wheni try to open it into my network behind a proxy , it request to re-authenticate?
id the proxy issue solved in eagle 8 or there is a special setting to work with proxy?
thank you
Will there be notification on when the new release (v8) that would support proxies?
Thanks!
