Error Message appears constantly when routing in Eagle 9.5.1 on Windows 10
- Mute
- Permalink
- Report
I have a pcb that I have been working on for quite a while across different versions of Eagle. Today the following error message popped up as I was working:
EAGLE has detected an unexpected condition. Please report this error and editing steps prior to this error to Autodesk. If possible, you should save your work to a backup file in case of any data corruption.
Unexpected Condition details: File: ../../src/obstrutils.cpp, Line 604
I have saved the files, closed Eagle completely and reopened the file. The problem persists on this particular board. I do not see it on other boards so far.
It happens when I try to start routing from an existing trace. Not all nets cause the issue, but quite a few do. When the error pops up, I can hit OK and then continue routing and the routing seems to work. But this message pops up constantly.
This is making it very difficult to work and I am concerned that the board will suddenly become unusable.
