EAGLE Forum
Welcome to Autodesk’s EAGLE Forums. Share your knowledge, ask questions, and explore popular EAGLE topics.
Eagle unable to resolve library path or too deprecated to function with current libraries
0 REPLIES 0
Message 1 of 1
anoduck
208 Views, 0 Replies
Eagle crashes on run everytime it runs. It appears eagle is looking for the mesa libs in the wrong location, and unable to locate them, crashes and burns.
It is trying to locate "zink_dri.so" and "swrast_dri.so" in "/usr/lib/dri/", when those are located in "/usr/lib/x86_64-linux-gnu/dri/". If a temporary solution is attempted to create a symbolic link between where Eagle thinks those libraries should be to where they actually are, a different error occurs stating the existence of an undefined symbol "xcb_dri3_buffers_from_pixmap_offsets".  A potential cause for reception of this error could be Eagle is too deprecated to be compatible with the current distributions of those driver libraries.
QT_XCB_GL_INTEGRATION=xcb_egl ./eagle
libEGL warning: DRI2: failed to open swrast (search paths /usr/lib64/dri)
MESA-LOADER: failed to open zink: /usr/lib/dri/zink_dri.so: undefined symbol: xcb_dri3_buffers_from_pixmap_offsets (search paths /usr/lib/x86_64-linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri, suffix _dri)
failed to load driver: zink
MESA-LOADER: failed to open swrast: /usr/lib/dri/swrast_dri.so: undefined symbol: xcb_dri3_buffers_from_pixmap_offsets (search paths /usr/lib/x86_64-linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri, suffix _dri)
failed to load driver: swrast
QXcbConnection: XCB error: 2 (BadValue), sequence: 402, resource id: 0, major code: 148 (Unknown), minor code: 24
Sandboxing disabled by user.
WebEngineContext used before QtWebEngine::initialize() or OpenGL context creation failed.
[1876900:1876909:0316/175620.260094:ERROR:nss_ocsp.cc(591)] No URLRequestContext for NSS HTTP handler. host: ocsp.digicert.com
[1876900:1876909:0316/175620.260143:ERROR:nss_ocsp.cc(591)] No URLRequestContext for NSS HTTP handler. host: ocsp.digicert.com
[1876900:1876909:0316/175620.260170:ERROR:nss_ocsp.cc(591)] No URLRequestContext for NSS HTTP handler. host: crl4.digicert.com
[1876900:1876909:0316/175620.260187:ERROR:nss_ocsp.cc(591)] No URLRequestContext for NSS HTTP handler. host: crl3.digicert.com
[1876900:1876909:0316/175620.261271:ERROR:nss_ocsp.cc(591)] No URLRequestContext for NSS HTTP handler. host: ocsp.digicert.com
[1876900:1876909:0316/175620.261306:ERROR:nss_ocsp.cc(591)] No URLRequestContext for NSS HTTP handler. host: ocsp.digicert.com
[1876900:1876909:0316/175620.261330:ERROR:nss_ocsp.cc(591)] No URLRequestContext for NSS HTTP handler. host: crl4.digicert.com
[1876900:1876909:0316/175620.261347:ERROR:nss_ocsp.cc(591)] No URLRequestContext for NSS HTTP handler. host: crl3.digicert.com
[1876900:1876909:0316/175620.328892:ERROR:nss_ocsp.cc(591)] No URLRequestContext for NSS HTTP handler. host: ocsp.digicert.com
[1876900:1876909:0316/175620.328936:ERROR:nss_ocsp.cc(591)] No URLRequestContext for NSS HTTP handler. host: ocsp.digicert.com
[1876900:1876909:0316/175620.328961:ERROR:nss_ocsp.cc(591)] No URLRequestContext for NSS HTTP handler. host: crl4.digicert.com
[1876900:1876909:0316/175620.328974:ERROR:nss_ocsp.cc(591)] No URLRequestContext for NSS HTTP handler. host: crl3.digicert.com
[1876900:1876909:0316/175620.329972:ERROR:nss_ocsp.cc(591)] No URLRequestContext for NSS HTTP handler. host: ocsp.digicert.com
[1876900:1876909:0316/175620.330010:ERROR:nss_ocsp.cc(591)] No URLRequestContext for NSS HTTP handler. host: ocsp.digicert.com
[1876900:1876909:0316/175620.330038:ERROR:nss_ocsp.cc(591)] No URLRequestContext for NSS HTTP handler. host: crl4.digicert.com
[1876900:1876909:0316/175620.330050:ERROR:nss_ocsp.cc(591)] No URLRequestContext for NSS HTTP handler. host: crl3.digicert.com
[1876900:1876909:0316/175620.440065:ERROR:nss_ocsp.cc(591)] No URLRequestContext for NSS HTTP handler. host: ocsp.digicert.com
[1876900:1876909:0316/175620.440110:ERROR:nss_ocsp.cc(591)] No URLRequestContext for NSS HTTP handler. host: ocsp.digicert.com
[1876900:1876909:0316/175620.440161:ERROR:nss_ocsp.cc(591)] No URLRequestContext for NSS HTTP handler. host: crl4.digicert.com
[1876900:1876909:0316/175620.440199:ERROR:nss_ocsp.cc(591)] No URLRequestContext for NSS HTTP handler. host: crl3.digicert.com
[1876900:1876909:0316/175620.441446:ERROR:nss_ocsp.cc(591)] No URLRequestContext for NSS HTTP handler. host: ocsp.digicert.com
[1876900:1876909:0316/175620.441485:ERROR:nss_ocsp.cc(591)] No URLRequestContext for NSS HTTP handler. host: ocsp.digicert.com
[1876900:1876909:0316/175620.441510:ERROR:nss_ocsp.cc(591)] No URLRequestContext for NSS HTTP handler. host: crl4.digicert.com
[1876900:1876909:0316/175620.441526:ERROR:nss_ocsp.cc(591)] No URLRequestContext for NSS HTTP handler. host: crl3.digicert.com
[1876900:1876909:0316/175620.505799:ERROR:nss_ocsp.cc(591)] No URLRequestContext for NSS HTTP handler. host: ocsp.digicert.com
[1876900:1876909:0316/175620.505837:ERROR:nss_ocsp.cc(591)] No URLRequestContext for NSS HTTP handler. host: ocsp.digicert.com
[1876900:1876909:0316/175620.505860:ERROR:nss_ocsp.cc(591)] No URLRequestContext for NSS HTTP handler. host: crl4.digicert.com
[1876900:1876909:0316/175620.505869:ERROR:nss_ocsp.cc(591)] No URLRequestContext for NSS HTTP handler. host: crl3.digicert.com
[1876900:1876909:0316/175620.506916:ERROR:nss_ocsp.cc(591)] No URLRequestContext for NSS HTTP handler. host: ocsp.digicert.com
[1876900:1876909:0316/175620.506947:ERROR:nss_ocsp.cc(591)] No URLRequestContext for NSS HTTP handler. host: ocsp.digicert.com
[1876900:1876909:0316/175620.506970:ERROR:nss_ocsp.cc(591)] No URLRequestContext for NSS HTTP handler. host: crl4.digicert.com
[1876900:1876909:0316/175620.506978:ERROR:nss_ocsp.cc(591)] No URLRequestContext for NSS HTTP handler. host: crl3.digicert.com
js: Uncaught SyntaxError: Unexpected token {
js: Failed to set referrer policy: The value 'same-origin' is not one of 'always', 'default', 'never', 'origin-when-crossorigin', 'no-referrer', 'no-referrer-when-downgrade', 'origin', 'origin-when-cross-origin', or 'unsafe-url'. The referrer policy has been left unchanged.
[1876900:1876909:0316/175620.657598:ERROR:nss_ocsp.cc(591)] No URLRequestContext for NSS HTTP handler. host: ocsp.digicert.com
[1876900:1876909:0316/175620.657640:ERROR:nss_ocsp.cc(591)] No URLRequestContext for NSS HTTP handler. host: ocsp.digicert.com
[1876900:1876909:0316/175620.657665:ERROR:nss_ocsp.cc(591)] No URLRequestContext for NSS HTTP handler. host: crl4.digicert.com
[1876900:1876909:0316/175620.657674:ERROR:nss_ocsp.cc(591)] No URLRequestContext for NSS HTTP handler. host: crl3.digicert.com
[1876900:1876909:0316/175620.661099:ERROR:nss_ocsp.cc(591)] No URLRequestContext for NSS HTTP handler. host: ocsp.digicert.com
[1876900:1876909:0316/175620.661127:ERROR:nss_ocsp.cc(591)] No URLRequestContext for NSS HTTP handler. host: ocsp.digicert.com
[1876900:1876909:0316/175620.661154:ERROR:nss_ocsp.cc(591)] No URLRequestContext for NSS HTTP handler. host: crl4.digicert.com
[1876900:1876909:0316/175620.661162:ERROR:nss_ocsp.cc(591)] No URLRequestContext for NSS HTTP handler. host: crl3.digicert.com
js: wafErrorsQueue
js: Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user's experience. For more help, check https://xhr.spec.whatwg.org/.
js: Uncaught TypeError: Cannot read property 'setItem' of null
Failed to create OpenGL context for format QSurfaceFormat(version 2.0, options QFlags<QSurfaceFormat::FormatOption>(), depthBufferSize 24, redBufferSize -1, greenBufferSize -1, blueBufferSize -1, alphaBufferSize -1, stencilBufferSize 8, samples 0, swapBehavior QSurfaceFormat::SwapBehavior(DefaultSwapBehavior), swapInterval 1, profile  QSurfaceFormat::OpenGLContextProfile(NoProfile))
zsh: IOT instruction  QT_XCB_GL_INTEGRATION=xcb_egl ./eagle
From the above assumption, the next step would be to attempt to run eagle in a virtual machine using an old, and potentially deprecated in it's own right, release of a Linux distribution that would provide those older libraries no longer used in modern linux systems.
Unless a potential work around can be discovered or a patch is created, this will end the attempt to get Eagle working, and a different solution will be searched for.
Labels (5)
0 REPLIES 0
Technology Administrators
