Eagle to Fusion suggestions
mario.brizida
mario.brizida
 Dear all;
When uploading a board to Fusion with correct definitions averythig goes right, but when generating a step file or igs, silkscreen and soldermask info is lost, and it's a very important info that should be transfered.
Another issue regards with silkscreen. Eagle only allows for silkscreen layer 25 for effect of Fusion trasfer, so when we use anoter layer we loose info or have a lots of work trasfering all info from any other layer to layer 25. If was allowed to use another layer than 25, would be easier to interchange info.
Do you think it's possible to implement these funcionalities on future versions of Eagle?
Thank you
jorge_garcia
Hello @mario.brizida,
Thanks for participating on our forums. We have plans to support more layers in the ECAD-MCAD integration, however it may take some time before we get to that (as usual lots of other development going on).
Please let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
yqliu
Hi @mario.brizida,
Thanks for your suggestion. If we support layers other than 25 for silkscreen, which layers will you use? It would be very helpful if you can share us how you will use the layers for different purpose.
Richard
