Eagle shouldn't check Internet connection until fully opened
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I don't mind Eagle checking the Internet connection, but this should happen in the background after Eagle has started up. Because Eagle should run fine for 14 days since last connect, it only needs to perform the 14-day check on startup without making any network connections, and if it detects it checked in within the last 14 days, then it should startup immediately, shaving seconds of startup time off. Once Eagle is fully up and the user is accessing it, then it can perform the check in the background to update the local last-checked-in-date.
