Eagle schematic simulation help
astrumik
astrumik
Hi all. I'm attempting to learn how to use Eagle and importantly the simulation fetchers after researching how to uses these tool I tried to produce a bridge rectifier circuit but ended up getting sum undesirable outputs from the simulation (shown bellow). Does anyone have any thoughts on what went wrong / ways to fix the problem.
Edit: All components used where from the ngspice-simulation folder.
Schematic (Input: sinusoidal @3V, 1Hz)
Voltage Output
astrumik
Turns out easy fix by just moving the ground. I would of just deleted the post but you don't seem to have the ability so here is the solution just in case anyone ever the same problem.
one-of-the-robs
Glad you found the fix. The simulation is doing exactly what you ask it to but you were initially asking the wrong question. Now that you've asked the right question all is well.
Community Visitor
Community Visitor
我按照你的电路图纸,为什么没有波形,请问
Community Visitor
Community Visitor
Do simulation results need to be set
Community Visitor
Community Visitor
