EAGLE is not saving user settings
jpdieffe
Message 1 of 15
jpdieffe
I just installed Eagle 8.3.1 (premium) on a new computer running Windows 10 Pro and none of my settings are saved after I close Eagle.
It doesn't remember any of my layer presets, it doesn't remember the number of maximum backup files to generate, basically nothing is saved after I close Eagle.
What's strange is that this does not happen on my computer running Windows 7.
Is anyone else with Windows 10 Pro seeing this? Is there a way to fix this?
Replies (14)
Message 2 of 15
rachaelATWH4
What folder have you installed EAGLE into? Did you let it do the default C:\EAGLE.x.x.x\ folder or did you change it to be in C:\Program Files\? If you moved it then that's probably the issue as that folder doesn't allow write access by user applications and so EAGLE wont be able to store any changes in its files.
Best Regards,
Rachael
Message 3 of 15
rachaelATWH4
So, I just tried this on a Linux VM.
In EAGLE v8.2.0 (the last version I had previously tried on the VM) I can successfully change a setting and save it. In my test case I tried changing the UI icon scaling as I am getting it running in Linux with HiDPI.
I then tried again with the latest v8.3.1 and it will not save the change to the setting at all. Something has definitely broken here somewhere between these two versions and changes to settings are no longer saved.
Best Regards,
Rachael
Message 4 of 15
rachaelATWH4
Best Regards,
Rachael
My quick work around is to close v8.3.1, open up an earlier version of EAGLE, make and save the changes and then close it and re-open v8.3.1. It's not ideal but for now it should get you going until Autodesk give a better work around or a fix is released.
Best Regards,
Rachael
Message 5 of 15
jorge_garcia
Hi Guys,
I have reported this issue to the developers and created a bug report.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Message 6 of 15
jpdieffe
Thanks Rachel for the workaround, I will try it shortly.
Glad to hear this will be fixed
Message 7 of 15
andrii.anpilogov
Hi jpdieffe,
The issue looks very strange and definitely is a critical one.
Could you please share some info about your Windows 10 Pro PC?
I need to know some details in order to reproduce your issue:
1) Your user name.
2) Your environment variables. Open cmd.exe and type 'set' then copy all output.
3) Your current earglerc.usr file (c:\users\[your user name]\AppData\Roaming\CadSoft\EAGLE\eaglerc.usr
4) What is your user system language (English?).
5) What is your system locale? Control panel -> Region -> Administrative (tab) -> Current language for non-Unicode program.
Feel free to send the info by direct message on this forum.
Regards.
Message 8 of 15
andrii.anpilogov
Hi @jpdieffe,
Thank you for providing extra information about your PC.
All looks good and I don't see anything known that could cause issues.
I tried 8.3.1 on Windows 10 Ent, MacOS and few Linux distros.
All of them save settings as expected.
I could only suggest deleting C:\Users\jpdie\AppData\Roaming\CadSoft folder and try again.
If it would not work then make sure C:\Users\jpdie\AppData\Roaming\CadSoft\EAGLE\eaglerc.usr is accessible for writing.
Hi @rachaelATWH4
What Linux distro did you use for testing?
Message 9 of 15
andrii.anpilogov
Hi @jpdieffe
I would also guess that Eagle 8.3.1 crashes on exit.
We don't know what causes it on your machine.
I would suggest clicking "File->Save all" after you made changes. At least this is easier than making the changes in another version of Eagle.
I'm sorry you have to experience such inconvenience.
Message 10 of 15
jpdieffe
Eagle 8.3.1 does not crash on exit actually.
And Eagle 8.3.2 has the exact same problem.
Both the different version of Eagle and the Save All trick work.
Interestingly, Eagle 8.2.2 wouldn't let Eagle 8.3.1 or Eagle 8.3.2 open .brd or .sch as the default program.
Thanks for the help,
Hope this gets fixed
Message 11 of 15
andrii.anpilogov
Hi @jpdieffe
Thank you for the feedback and info about 8.3.2.
I still think that Eagle crashes (or at least doesn't exit properly) on your particular Windows 10 PC.
Because this is only one explanation of the described issue.
And as far we can't reproduce it and there are no other users who reported the same issue we need your help to solve it.
Could you check if Eagle exits properly?
1) Open command line (cmd.exe)
2) Execute 'c:\EAGLE 8.3.2>eaglecon.exe'
3) Do some changes in settings (icon size, for example) and close Eagle.
4) in the same command line type: 'echo %ERRORLEVEL%`
It will print return code (a number): 0 - Eagle exits properly, any other number - error.
Hope you could post the result here.
Thank you.
Message 12 of 15
sidroberts
Community Visitor
Community Visitor
EAGLE 9.6.2 still has the same problem with Windows 11 Pro. Fortunately doing Save All does save the customizations. But it must be done from the Schematic for customizations done there, and from the Control Panel for customizations done there.
Will this be an issue with every new Windows version?
Message 13 of 15
james.myersBBY4Y
Observer
Observer
I had this problem with 9.6.2, looking at the properties of C:\Users\Username\AppData\Roaming\CadSoft, I could see it was set to read only (checkbox) , deselecting this (and for all subfolders) fixed the issue and my setting changes now appear when restarting the program.
Cheers!
James
Edit: This is for Windows 10
Message 14 of 15
DBINKLEYLH9CM
Community Visitor
Community Visitor
Thanks! I shall give this a try!
Message 15 of 15
sroberts
Community Visitor
Community Visitor
I got it to work. I usually open schematics by going to the schematic file and double-clicking; which then starts up EAGLE. I was able to log in from the EAGLE control panel when I did not have a schematic open.
