Hello, after upgrading to Eagle 8, eagle.exe crashes on startup. Have used E6 and 7 fine for years, new Eagle 8 just doesn't work for me. Generic screenshots are attached. Tried reinstalling a few times to no avail; any other advice? Using this for work so I need to get this fixed yesterday...
Solved by carrollsandra. Go to Solution.
Solved by jorge_garcia2. Go to Solution.
ok, I tried to uninstall eagle and it will not un-install
I get this
And yes I am admin on this computer.
wish it said where it was trying to create a temp file, that would be helpfull
Hi @ all,
same problem here.
the further EAGLE Versions worked as well as they should be.
For some small projects within the university i try to install EAGLE Version 8.0.1
It´s a Windows 7, 64 bit System.
.NET Framework Version 4.6.1
Install Directory: C:\EAGLE 8.0.1
Lavasoft wasnt installed
After several attempts to install EAGLE, I disabled Windows Firewall and deinstalled Sophos Anti Vir.
Unfortunately without any success.
Within the EAGLE Install Directory a debug.log with the following content was created aftertrying to start EAGLE.exe
[0220/134140:ERROR:gles2_cmd_decoder.cc(12613)] [GroupMarkerNotSet(crbug.com/242999)!:28B6770800000000]GL ERROR :GL_INVALID_ENUM : glTexStorage2DEXT: <- error from previous GL command
[0220/135721:ERROR:gles2_cmd_decoder.cc(12613)] [GroupMarkerNotSet(crbug.com/242999)!:F816D60600000000]GL ERROR :GL_INVALID_ENUM : glTexStorage2DEXT: <- error from previous GL command
[0220/141747:ERROR:gles2_cmd_decoder.cc(12613)] [GroupMarkerNotSet(crbug.com/242999)!:981B360800000000]GL ERROR :GL_INVALID_ENUM : glTexStorage2DEXT: <- error from previous GL command
[0220/141833:ERROR:gles2_cmd_decoder.cc(12613)] [GroupMarkerNotSet(crbug.com/242999)!:D80D0D0800000000]GL ERROR :GL_INVALID_ENUM : glTexStorage2DEXT: <- error from previous GL command
[0220/143403:ERROR:gles2_cmd_decoder.cc(12613)] [GroupMarkerNotSet(crbug.com/242999)!:389CB10900000000]GL ERROR :GL_INVALID_ENUM : glTexStorage2DEXT: <- error from previous GL command
I would be grateful to anyone who has some tips, how to solve this issue.
Thank you and greetings from Dortmund
Daniel
Hello Daniel,
I hope you're doing well. In your case the crash seems to be related to a video driver issue. Could you try updating to the latest video drivers for your hardware?
Please accept as solution if my post fully resolves or you issue, or reply with additional details if the problem persists.
Let me know if there's anything else I can do for you.
Best Regards,
Hi Smgvbest,
I hope you're having a good day. Could you get us a crash report? That might give some insight as to what is going on. Here's the procedure:
When a program crashes (the process has stopped working or disappears), an event log file can be helpful for the development team to troubleshoot problems. Follow the steps below to find event logs(copied from http://www.cyberlink.com/support/faq-content.do?id=10449😞
Windows 7:
Hi Smgvbest,
Thank you for the crash report, it seems you are running 8.0.0 can you confirm or deny that? If you are running 8.0.0 then I encourage you to update to 8.0.1 since there were several bug fixes incorporated into that release.
The crash report shows that the issue is with ntdll, try some of the fixes here and let me know if any of that helps.
Either way I'll take this report to the devs and see what they come back with.
Best Regards,
thought I was on 8.0.1 but just downloaded it and the install is hung.
it just hangs there on Visual C++ redistribution doing nothing
if I click anywhere I just get a ding sound from windows. can't close it, can't move it, cant' do anything with the dialog box.
any log file I can send to help figure this out.
Hello @carrollsandra,
Go ahead an uninstall EAGLE completely from your system and then reinstall 8.0.1. The last part of the installation where it installs the C++ redistribution is the one that takes the most time so wait on that one.
Let me know if this doesn't resolve the situation. Again look carefully to make sure you don't have Lavasoft installed, it is a little sneaky.
Best Regards,
see my previous post dated 02-18-2017 04:49 PM
I can not uninstall 8.0 due to that error, and now the 8.0.1 install that hung on C++ libraries won't uninstall either.
after 24hrs of it being hung I killed the install. i think 24hrs is way more then enough time to install anything.
Also got the message that Eagle has stopped working (ASUS laptop F553M, win10 64bit) after install of Eagle 8.0.1.
Lavasoft programs were not installed on the PC but a Lavasoft folder containing many programs was in the programs x86 folder. Possibly supplied with the PC.
Tried to run the Lavasoft installer in this folder but got a dialog box stating that the program may not have uninstalled properly.
Removed the entire Lavasoft folder, downloaded the Lavasoft webcompanion, installed then uninstalled (as previously suggested), rebooted laptop and now Eagle 8.0.1 runs ok (so far).
CFJ
I hope you're doing well. Yes, definitely 24 hours is more than enough time for a program to install.
Let's try this delete the Eagle folders at the root of C. Then try to uninstall again. If this still fails, let me know. I'll reach out through direct messaging to see if we can get this resolved.
Best Regards,
ok,
I deleted the directory then went into programs and features and uninstalled it there.
I then reran the install and it's hanging on the V++ stuff still, been running since last night.
i terminated that process.
here's the plus, I can now run eagle 8.0.1.
the minus when I exit it it crashes (attached event log)
it seems to run ok though, but will need more time to know for sure
I don't like the VC++ stuff not finishing and maybe part of why I have the crash at the end now?
I'm glad that 8.0.1 is working for you. I would encourage you to try to see if you can update your video drivers since those can sometimes cause issues with EAGLE's operation.
Best Regards,
Jorge Garcia
Good morning,
I have just installed the student version of Eagle 8.1.0 on my computer and I am experiencing the same problem. Everytime that I launch the application it crashes:
Im running it in:
I have no Lavasoft software (I checked) installed but I do have an AMD ATI Radeon HD 3400 Graphics card. I already updated the driver (since I read somewhere that this could possibly correct the issue). I also installed this same version on my laptop but in Ubuntu OS and there is no problem. My laptop works with:
Any help guys? I ran out of ideas.
Thank you,
AG
on my side it seemed to crash when i clicked on "eagle" (see #1 on screenshot)
once i went through the file menu (#2 on screenshot) and chose something, everything started working semi normal.
well, at least i can open up brd / sch now.. haven't done anything else since was frustrated and needed a break.
not sure where eagle stores its settings so cant check what it changed path to; et al.
Windows 10 64-Bit
Hi @Anonymous
Thanks for participating in the forums. Look in the README file that comes with EAGLE, you'll find it in the doc folder of EAGLE's installation directory. It will reference running EAGLE through a batch file to force software rendering. Follow those instructions and you should see EAGLE open just fine.
Best Regards,
Good Morning,
I have searched for the README document in the C:/EAGLE_8.1.0/doc and there is nothing. I did a quick search in the whole directory and got any matching result either. I also did search it on google with no result. Could you paste the code of the batch file here? Or send it to me?
Thank you,
AG
