Eagle can't Sync To Fusion 360 not let push 3d vew in the web Account
gothicdreams.crissis
the prolem, i need a preview 3D model on my board try to usethe last year from eagle (RIP)
but try sync de fusion 360 extension on Eagle 9.5.2 (reason is the most stable version for me)  the appear window Sync to fusion thats say : Looks like haven't used fusion 360 before...
1- i have the last version of the fusion 360
2- the sync and push the fusion 360 in the web are unavaible.
3- persist the problems to push on fuson 360 local...
Really wants use the ECAD with this problems??? i try the use before migrate to another sofware but is very rude from fusion...
jorge_garcia
Hello @gothicdreams.crissis ,
I hope you're doing well. What I would recommend now is to just upload the files to Fusion and generate the 3D model from there. The latest(and last) release of EAGLE was 9.6.2 if you are open to trying that one, then that could be a way as well.
EAGLE's EOL is less than a year away, since you have access to Fusion I would consider trying to make the move now. I'll be happy to help with any issues you may run into in trying to transition to Fusion.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
