Eagle 9.6.2 Won't Open
ryan.brewer9R5KC
ryan.brewer9R5KC
Eagle 9.6.2 will not open when attempting to launch the .exe. I have tried:
-Launching .exe directly.
-Launching from "eagle_SW_OpenGL.bat".
-Opening .brd, .sch, .prj files.
-Uninstalling and reinstalling 9.6.2.
-Installing older versions back to 9.5.1.
-Renaming libeay32.dll to libeay32.dll.bak, per https://knowledge.autodesk.com/support/eagle/troubleshooting/caas/sfdcarticles/sfdcarticles/Eagle-cr....
-Clearing roaming and cache data.
-Running as administrator.
-Uninstalling Windows updates from the past two months.
None of these attempts have allowed me to open Eagle. I am unaware of what change caused this issue, as it worked one day and then would not open when I arrived the next morning. Does anyone have any input on this issue? Autodesk support has been unable to resolve.
@jorge_garcia
jorge_garcia
Hi @ryan.brewer9R5KC,
I hope you're doing well. Do you know if your Windows PC did an update recently?
That's the only thing I could think of that would not let EAGLE start. I'm going to send you a DM to see what we can figure out.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
@jorge_garcia i have installed eagle 9.6.2 on 3rd march 2021. i have downloaded and installed the software and now its not epening...it shows loading....mine is windows 10
ryan.brewer9R5KC
@Anonymous
The issue on our system was related to the program defaulting to using a NVIDIA high performance graphics controller instead of the integrated Intel controller. The issues started following a NVIDIA graphics driver update. Ultimately setting Eagle to always use the Intel controller fixed the problem.
Here is a link to how to set the default controller for an app:
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-force-your-laptop-to-Run-with-Graphics-Processor-vs-the-default-Integrated-Graphics-for-InfraWorks.html
Just do this for Eagle instead of Autodesk.
hii @ryan.brewer9R5KC  my computer has integrated intel uhd 600 graphics....its not opening..i'm waiting for 1 hr
jorge_garcia
Hi @Anonymous ,
Have you attempted the other suggestions on this thread. If EAGLE doesn't start at all it might be LIBEAY32.dll issue.
https://knowledge.autodesk.com/support/eagle/learn-explore/caas/sfdcarticles/sfdcarticles/Autodesk-EAGLE-can-t-go-online-after-signing-in.html?st=LIBEAY32
Best Regards,
Jorge Garcia
johnsuhr
Update *** This worked
Rename "LIBEAY32.dll"
Follow the steps:
  1. Navigate to "C:\EAGLE 9.x" and find the file "LIBEAY32.dll".
  2. Rename the .dll by appending .bak at the end of the file name: "LIBEAY32.dll.bak".
  3. Start Eagle again, the program should open with no issue.
I know this is older but I just installed 9.6.2 on a new computer. When I open it seems like it will and then never appears.
windows 11 pro
os build 22621.2134
NVidia RTX A4500
I tried the right click and selected the Eagle.Exe for the high performance graphics and didn’t change. Any ideas? Thanks
