Hi @m.henrichZN4UT ,
I hope you're doing well. Here's what I recommend, write you shortcuts into a script file. This is ultimately portable so they can follow you regardless of what version of EAGLE you are working with.
Here's the contents of the default-assign.scr which is a good starting point for setting up your own shortcuts.
# Default ASSIGN Configuration Script
# This file can be used to configure the editor windows.
# GENERAL:
ASSIGN C+M MOVE;
ASSIGN C+Z UNDO;
ASSIGN C+Y REDO;
ASSIGN CS+C COPY;
ASSIGN CS+A ADD;
ASSIGN C+D DELETE;
ASSIGN C+W WIRE;
ASSIGN C+I INFO;
ASSIGN C+T TEXT;
ASSIGN CS+N NAME;
ASSIGN CS+P POLYGON;
ASSIGN C+F 'RUN find.ulp';
#ASSIGN C+X CHANGE;
#ASSIGN A+A ATTRIBUTE;
ASSIGN C+G NEWGROUP;
ASSIGN CS+G UNGROUP;
BRD:
ASSIGN C+E ERRORS;
ASSIGN CS+D 'DRC;'; # Executes DRC without opening DRC dialog. For dialog sk
#ASSIGN CS+D DRC; # Opens DRC dialog.
ASSIGN CS+V VALUE;
ASSIGN CS+R RIPUP;
#ASSIGN A+R RATSNEST;
ASSIGN C+H HOLE;
# Route related key assingments
ASSIGN A+G Set Obstacle_Mode Ignore;
ASSIGN A+P Set Obstacle_Mode Push;
ASSIGN A+W Set Obstacle_Mode Walkaround;
ASSIGN A+1 Set Via_Pattern Perpendicular;
ASSIGN A+2 Set Via_Pattern Angle_Right;
ASSIGN A+3 Set Via_Pattern Angle_Left;
ASSIGN A+4 Set Via_Pattern Stagger;
ASSIGN A+A DECSpacing; # While multi-routing, DECrease the spacing between routed wires
ASSIGN A+S INCSpacing; # While multi-routing, INCrease the spacing between routed wires
ASSIGN A+D MINSpacing; # While multi-routing, set the spacing to the MINimum design rule.
ASSIGN A+Q SwaPEnd; # swap's routing to the opposite airwire endpoint
ASSIGN C+1 Route;
ASSIGN C+2 RouteMulti;
ASSIGN C+3 RoutEDiff;
ASSIGN C+4 QRouteAirwire;
ASSIGN C+5 QRouteSignal;
ASSIGN C+6 QRouteMulti;
ASSIGN C+7 QRouteSmooth;
SCH:
ASSIGN C+E ERRORS;
ASSIGN CS+E ERC;
ASSIGN CS+I INVOKE;
ASSIGN CS+V VALUE;
ASSIGN CS+S SMASH;
ASSIGN A+N NET;
LBR:
ASSIGN C+E EDIT;
DEV:
ASSIGN A+C CONNECT;
ASSIGN A+P PACKAGE;
SYM:
ASSIGN A+P PIN;
PAC:
ASSIGN C+H HOLE;
ASSIGN A+P PAD;
ASSIGN A+S SMD;
Jorge Garcia
Product Support Specialist for Fusion 360 and EAGLE
