Hello.
I am passionate about electronics and have been using the Eagle editor for almost 20 years.
Of which a very long time on the Linux platform.
For obvious reasons I use the free license.
Recently I wanted to get acquainted with novelties that have been added to the latest version of Eagle. That's why I started to run it.
I encountered the following error:
08:23 kaktus@donica:/opt/eagle-9.2.0$ ./eagle terminate called after throwing an instance of 'std::runtime_error' what(): locale::facet::_S_create_c_locale name not valid Przerwane 08:23 kaktus@donica:/opt/eagle-9.2.0$
which I handled as follows:
08:33 donica:/opt/eagle-9.2.0# echo "en_US.UTF-8 UTF-8" > /etc/locale.gen 08:33 donica:/opt/eagle-9.2.0# locale-gen Generating locales (this might take a while)... en_US.UTF-8... done Generation complete. 08:33 donica:/opt/eagle-9.2.0# ./eagle QStandardPaths: wrong ownership on runtime directory /run/user/504, 504 instead of 0 Sandboxing disabled by user. inotify_add_watch("/root/.local/share/Eagle/cloud-processing/3d-models-jobs-EF5KMX5AGCHA.json") failed: "No such file or directory"
You can see some warnings, but this allows to run the program.
The problem is that the changed configuration causes clutter in my environment. The language settings are confused, which is not good.
My system has a Polish interface.
Is this situation known to somebody?
Maybe there is a better solution that I don't know?
Solved by kaktus. Go to Solution.
Instead of completely replacing your locales list, it should be acceptable to have both Polish and US enabled. The error you got looks like Eagle wants to use the minimal "C" locale, which should ALWAYS be present on a properly installed Linux system.
Hello my mate.
Especially for you I have found a solution.
There is nothing better than working alone.
This problem is well known (perhaps only in my country). And it has nothing to do with correct or incorrect installation and configuration of the system. But so far no one has indicated the correct and complete solution.
So I do it first, on your forum.
The configuration required by Eagle is problematic. Only for the fact that it requires foreign-language locales. Without this the program does not start.
To solve the problem is necessary:
restart the configuration of the locales with the command
dpkg-reconfigure locales
select additional settings for the English language
en_US.UTF-8
validate the choice.
The shares will be confirmed by
root@programator:/opt/eagle-9.2.1# dpkg-reconfigure locales
pl_PL.UTF-8... done
en_US.UTF-8... done
From now on, the Eagle will run correctly and without errors.
Thank you for your contribution and willingness to help.
I greet you cordially!
I consider the subject to be closed.
I am using eagle 9.4.2, i followed yours instruction but it still throwing error
OK, that no longer looks like a locale error but rather a MESA/DRI error. You probably need an LD_PRELOAD - sorry, I don't have time to search for that thread right now but it got bumped not that long ago.
