I installed Eagle 9.2.2 on Windows 10 but it doesn't launch. It appears a windows with the head "Sign in" for a few seconds and then crashes. I tried to replace the "libeay32.dll" file as it's said in https://forums.autodesk.com/t5/eagle-forum/eagle-9-1-x-won-t-start-on-windows-10/td-p/8233750/page/2... but there is no changes. I searched the crash log:
Application name with errors: eagle.exe, version: 0.0.0.0, timestamp: 0x5bd38026
Module name with errors: ig9icd64.dll, version: 24.20.100.6293, timestamp: 0x5baa900f
Exception code: 0xc000041d
Error offset: 0x000000000062f2db
Process identifier with errors: 0x47bc
Start time of the application with errors: 0x01d4abec37d1e1f1
Application path with errors: C: \ EAGLE 9.2.2 \ eagle.exe
Module path with errors: C: \ WINDOWS \ System32 \ DriverStore \ FileRepository \ 64jp6293.inf_amd64_9bca36afef322a4a \ ig9icd64.dll
Report Identifier: ede1dbab-c365-4e04-8f33-c587362ed094
Can anyone help?
Solved by hudriwudri. Go to Solution.
The failing module ig9icd64.dll is the Intel graphics driver. You can try
