EAGLE 9.1.2 does not simulate with schematics simulating with 9.1.1
HarrySatt
HarrySatt
Hi
After updating EAGLE from 9.1.1 to 9.1.2 this morning I had some severe problem with simulating schematics I was able to simulate with EAGLE 9.1.1. 9.1.2 seems to save the <filename>.sch.sim  as  <filename>.sch.sim.txt which is not the filename the simulation expects. So an error is thrown. If I simulate the same schematic with EAGLE 9.1.1 there is no problem as you can see in the photos attached.
regards, harald.
jorge_garcia
Hi @HarrySatt,
I hope you're doing well. Try simulating one of the examples that comes with EAGLE, does it simulate? If you are working with a customized build we can't support it. It's important to use the NGSpice version that ships with EAGLE always since we have adjusted EAGLE to properly interface with it.
I'll ping our devs to take a look but keep in mind that you should be using the NGSpice version that ships with EAGLE.
Please let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
