EAGLE Forum
Welcome to Autodesk’s EAGLE Forums. Share your knowledge, ask questions, and explore popular EAGLE topics.
Eagle 8 and 8.1 freezes on Windows 10
17 REPLIES 17
Message 1 of 18
oozcan42
2778 Views, 17 Replies
Hi, downloaded Eagle 8.1 and still freezing on windows 10. i reinstalled twice windows and eagle. but when opened any dropdown menu or popup menu eagle freezing. when eagle freeze i need to close it from task manager.
17 REPLIES 17
Message 2 of 18
jorge_garcia2
in reply to: oozcan42
Hi @oozcan42,
I hope you're having a good day. There are a few things to try here:
1) Try starting EAGLE using the eagle_SW_OpenGL.bat file that is in EAGLE's installation directory.
2)If that doesn't help, then make sure you are using the most up to date NVIDIA drivers for your hardware.
Please let me know if you continue to run into problems.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Message 3 of 18
oozcan42
in reply to: jorge_garcia2
Sorry it didnt worked still freezing. i installed old versions(before Autodesk) of Eagle but they froze too. But any other applications(Autodesk 3dsmax,Adobe Photoshop,Microsoft Office, Games vs.) dont freeze. Only Eagle freezing.
My system.
CPU i7 5700hq
Ram 2x8 GB
storage 120 gb ssd + 1Tb hdd
graphic intel gma 5600 + nvidia gtx960m
 All drivers update.
What is the problem? Please help.
Message 4 of 18
jorge_garcia2
Hi @oozcan42,
I hope you're doing well. Could you check carefully to see if you have either bitdefender or lavasoft software installed on your machine? Did you make sure to install EAGLE to the root of C? Are you running the latest 8.1.0 version of EAGLE?
From the video it looks like there may be some other process running on your system that seems to interfere with EAGLE.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
Message 5 of 18
slearyHRNGX
I also have this freezing issue with 8.1 on windows 10.  Seems to be related to the follow me feature.
Message 6 of 18
jorge_garcia2
in reply to: slearyHRNGX
Hi slearyHRNGX,
I hope you're doing well. Could you download the latest 8.1.1 and try it out? If it still happens could you post a screencast showing the crash happening. If it is happening while you are using the follow me router then there might be a bug that needs to be addressed.
Best Regards,
Jorge Garcia
Message 7 of 18
oozcan42
Message 8 of 18
jorge_garcia2
Hi oozcan42,
I hope you're doing well. I apologize for the inconvenience you are experiencing. Let's try this, could you follow these instructions and get me an error log for EAGLE.
https://helpx.adobe.com/photoshop-elements-editor/using/find-crashlogs.html
Hopefully that will contain information that can guide us to find what is happening on your specific machine. Thank you for posting the videos since it makes very clear what's going and avoids having to confirm simple details like what version you are using.
Best Regards,
Jorge Garcia
Message 9 of 18
oozcan42
General Tab;
eagle.exe programının 0.0.0.0 sürümü, Windows ile birlikte çalışmayı durdurdu ve kapatıldı. Sorun hakkında daha fazla bilgi olup olmadığını görmek için Güvenlik ve Bakım denetim masasında sorunun geçmişini denetleyin.
 İşlem Kimlik No: 1ee4
 Başlatma Saati: 01d3055dc51617f8
 Sona Erdirme Saati: 4294967295
 Uygulama Yolu: C:\EAGLE 8.2.2\eagle.exe
 Rapor Kimliği: 74b1366a-1ec6-421c-be85-5bb5c0125e2c
 Hatalı paket tam adı:
 Hatalı paketle ilgili uygulama kimliği:
Message 10 of 18
jorge_garcia2
Hi @oozcan42,
I hope you're doing well. Thank you for posting the screenshot and the hang report. Try this:
Rename the EAGLE 8.2.2 folder to EAGLE-8.2.2(no space) this has helped a few users. Since you are using a different language interface it's possible that EAGLE is not liking the space there because the error talks about a bad package name.
Best Regards,
Jorge Garcia
Message 11 of 18
brussellYPRWV
I had this same issue with EAGLE 8.x.x and every thread that I looked at didn't have a solution that worked for me. I fixed it by running it in compatibility mode for Windows 7. Everything runs smoothly now. Hope that helps.
Brandon
Message 12 of 18
nj55-yorg
adding the - did work,
also i removed the folders that were outdated versions of eagle
Message 13 of 18
Dear user
I had the same problem but when I make a project thin the problem was solved
Message 14 of 18
oliviadevid143
Hello there,
I'm sorry to hear that you're experiencing issues with Eagle 8.1 freezing on your Windows 10 computer. Here are a few troubleshooting steps you can try:
  1. Check for software updates: Make sure that both Eagle and Windows 10 are fully updated with the latest patches and updates. Sometimes, software bugs can cause freezing issues that are resolved in software updates.
  2. Check system requirements: Ensure that your computer meets the minimum system requirements for running Eagle 8.1. You can check the system requirements on the Eagle website.
  3. Try running Eagle as an administrator: Right-click on the Eagle icon and select "Run as administrator" to see if this resolves the issue.
  4. Disable any antivirus software: Temporarily disable any antivirus software you have installed and see if the issue persists. Some antivirus programs can interfere with Eagle and cause it to freeze.
  5. Uninstall and reinstall Eagle: If none of the above steps work, try uninstalling Eagle and reinstalling it again. Make sure to delete any leftover files and folders before reinstalling.
If none of these steps work, you may want to consider reaching out to Eagle support for further assistance.
Best Regards
Olivia devid
Message 15 of 18
theguru_999
You might want to try looking at the date next time. The last reply was solved 5 years ago! LOL! Looks like a ChatGPT reply. That's about the most generic fix reply possible.
You missed....
'Try restarting your computer'
'Ensure your power supply has enough watts to run your PC under load'
'Check for built-up dust in your PC and graphics card'
Hahaha!
Come on are you serious, latest updates? OS updates are what causes problems. Look how many noobs got caught not looking when Microsoft tried to force-update Win 7 PCs to Win 10 and those computers no longer booted. Similar issues are happening now with Win 11.
The PCs people are using can run Eagle just fine. Eagle 9.x will run even on a modest PC from 2010 (Core2Duo 2GHz).
As for reaching out to Eagle Support, that's hilarious buddy. The original person **WAS** reaching out to support here. You know what this forum is, right? Or hmmm, maybe not.....
Message 16 of 18
oozcan42
in reply to: theguru_999
Wow!
Message 17 of 18
oozcan42
Thanks for your reminding. Five years ago this problem was not solved. But i think new versions of Eagle works on Windows 10. Or lets try it.
Message 18 of 18
oozcan42
Eagle 9.6.2 works good on Windows 10 🙂
