Hi. I have downloaded E8.1.0 and it started the first time after installing. I got so far as to add a new custom part. The second time and from then on, the program won't start. After the splash screen a new window opens up with the message, "This webpage is not available" There is ERR_INVALID_CHUNKED_ENCODING error. The details provide in that message are:
The webpage at contapi.circuits might be temporarily down or it may have moved permanently to a new web address.
Thanks in advance for your assistance.
Edited by
Discussion_Admin
Solved by rjuncosa. Go to Solution.
I ran EAGLE from the batch file and the response was the same. I have tested this with no anti-virus programs running.
Bob
Nothing changed. The OS is Win7 x64. I have uninstalled 8.1 and installed 8.02. Same issue. I uninstalled that and when back to 8.1. No change.
The only thing I did that was "non-standard" was that I did not let the program install in c:\EAGLE. I installed it in the Programs folder. (c:\Program Files\EAGLE 8.1.0)
Bob
(edit: Make that Win7x64)
It is now installed off of the root but that did not solve the issue. Same error message.
Well I got further. I did get the log on screen and entered my email address. Then I got the password screen and entered it. That is as far as it got. After that I got the same error as before. "This webpage is not available" ERR_INVALID_CHUNKED_ENCODING
Ah but there is good news. I just did a search on that error code. As it turns out, it can be caused if the proxy settings are turned on for internet connections. I do not need/use a proxy but I have found from time to time that this setting gets changed somehow. I used to have to go in and turn that off every once in a while. I haven't had to do that lately.
Something must have changed those settings. I can't say for sure if it was EAGLE. Anyway, with the proxy off, this are working.
Thanks.
Bob
Hi..
please help me.
I have problem..
"eagle software can't sign first time"
I think this software, can't connect to server.
Thanks !
