EAGLE Forum
Welcome to Autodesk’s EAGLE Forums. Share your knowledge, ask questions, and explore popular EAGLE topics.
EAGLE 8.1.0: Walkaround and Obstacle avoidance land in EAGLE!
21 REPLIES 21
Message 1 of 22
matt.berggren
3377 Views, 21 Replies
Hi All --
(Just when we American's thought they were going to bed...  🙂  We are happy to announce that the latest update to EAGLE is now available from within your installed software.  To access this, locate the License Information menu under the Control Panel.  You should get an option to Download Update
This update introduces, amongst other things, the Walkaround and Obstacle Avoidance mode for Routing!  (On by default)   This is not an extension of the Follow Me router but rather, a completely new set of routing tools which follow design rules for clearance and which, when combined with Loop Removal which we'd introduced in 8.0, a simplified Spacebar to change routing layers, we hope these vastly improve your routing experience for EAGLE PCB.
The commands are on the far-left hand side of the Routing toolbar when in routing mode.  You can continue to route without constraint or use the new obstacle avoidance to avoid costly mistakes!
For those that hadn't seen this in action, have a quick peak at the gif below and please please please provide your feedback!
Best regards,
Matt
21 REPLIES 21
Message 2 of 22
Hi All --
For those looking for a direct download link, here's the latest!  (I know some folks have had issues with the update...we're updating links on the servers and it'll be available everywhere soon!)
 http://trial2.autodesk.com/NET17SWDLD/2017/EGLPRM/ESD/Autodesk_EAGLE_8.1.0_English_Win_64bit.exe
 http://trial2.autodesk.com/NET17SWDLD/2017/EGLPRM/ESD/Autodesk_EAGLE_8.1.0_English_Mac_64bit.pkg
 http://trial2.autodesk.com/NET17SWDLD/2017/EGLPRM/ESD/Autodesk_EAGLE_8.1.0_English_Linux_64bit.tar.g...
Best regards,
Matt
Message 3 of 22
C.Nicks
in reply to: matt.berggren
Hey Matt,
Great stuff with the new routing mode. It's very snappy and feels quite polished.
Sometimes while using it I want to toggle the walkaround off and on to manually place tracks in select areas. Is there a way to map it to a shortcut?
I checked eaglerc.usr, but did not see any new option for it.
Best Regards,
Cameron
Eagle Library Resources
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
Message 4 of 22
The features sound really nice, but even 50% of a subscription still is a subscription model which my administration won't approve.
Message 5 of 22
It crashes hard when I try to run it.  Win 7, Dell XPS processor i7, 16G Ram, 1T hard drive.  Nothing exotic on displays but am running two monitors.  8.0 works great.  8.1 - won't even get to control panel, crashes and sends data to Microsoft.
Message 6 of 22
Hi bcarterW8DV4,
I hope you're doing well. Try running EAGLE using the eagle_SW_OpenGL.bat file that is in the EAGLE installation directory. Does this allow EAGLE to run for you without crashing?
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Message 7 of 22
It did, but when I tried to create a shortcut it evidently deleted the batch file.  There is only the shortcut left in the Eagle 8.1 directory, no batch file.  And the shortcut can't find the batch file.  So if you could send me the batch file I could try again, this time making a copy of it somewhere in case it deletes again.
Message 8 of 22
nnovotney
in reply to: bcarterW8DV4
There should be a setting for the preferred clearance, as well as the min allowed clearance.  Otherwise you get a lousy route like where it routes on top of C1 when there is a ton of room  adjacent to its left.  Setting the min larger is not good, since in tight situations the min is the only solution.
Message 9 of 22
jorge_garcia2
in reply to: nnovotney
Hi nnovotney,
I hope you're doing well. I know it's not clear in the video because you can't really see clicks. The Obstacle avoidance engine doesn't hug components, as long as you are not running into an obstacle you are just routing manually so you can get a larger clearance if you wish just by drawing it manually.
Additionally, the Walkaround mode respects netclasses so you can use those to gain some additional control over the routing.
Best Regards,
Jorge Garcia
Message 10 of 22
That's actually something worth noting as net classes in EAGLE previously were of little use unless you were auto routing so a lot of people will likely never have bothered using them. Now with Walkaround and Obstacle Avoidance, and even more so when Push and Shove comes to EAGLE, setting up the net classes will become far more important so it's probably something you should provide more guidance on in a blog post or something for people who may not be familiar with this.
Best Regards,
Rachael
Message 11 of 22
nnovotney
in reply to: rachaelATWH4
Hi Jorge:
What I'm simply saying is, suppose you'd like to maintain 30mils separation (preferred clearance) between a trace and other components, UNLESS there is no room to do so (such as at the package itself).  Then in tight situations, allow it to drop down to 5 mils.  But that does NOT mean you want a 5 mil spacing everywhere--you want 30.  Saying you can manually move it makes the new mode rather useless.  Is what I'm  describing already implemented (perhaps using the net classes)?  I'm glad to see progress is being made in a positive direction.....one step at a time.
Message 12 of 22
matt.berggren
Actually I totally hear you and I think this is a valid suggestion! I’ve already brought it up within our development discussions as something we should look into, so thank you for suggesting it. I agree, if implemented properly it could prove super userful!
Best regards,
Matt – Autodesk.
Message 13 of 22
matt.berggren
Best regards,
Matt – Autodesk.
Message 14 of 22
nnovotney
That's actually something worth noting as net classes in EAGLE previously were of little use unless you were auto routing ....
Hmm, I think they were used for ERC checking as well, even if manual routing was the name of the game. In any case, they may get used more nowadays. Hopefully both preferred & min clearances can eventually be set.   Some routers also have a spreading function that can also post-process traces and space them out some around wide-open areas.  No need to increase the chance of short circuits.
Message 15 of 22
in reply to: jorge_garcia2
Hi, I have the same problem, but running EAGLE using the eagle_SW_OpenGL.bat file have same consequences -> It crashes.
I'm using Win7, same like bcarterW8DV4
Message 16 of 22
jorge_garcia2
Hi wwwiktoor,
I hope you're doing well. Are you using two monitors as well? Please let me know since this is popping with other users and it would be good to have some association for a cause.
Let me know.
Best Regards,
Jorge Garcia
Jorge Garcia
Message 17 of 22
No, I'm using notebook with only one monitor, but with dual graphics. My HW is: AMD E2-3000M APU, 4GB RAM, dual graphics AMD Radeon HD 6470M and AMD Radeon(TM) HD 6380G. Operating system: Windows 7 Home Premium 64-bit Service Pack 1. I hope that my description will be helpful.
Message 18 of 22
jorge_garcia2
Hi wwwiktoor,
I hope you're doing well. Have you tried updating to the latest drivers for your video cards?
Best Regards,
Jorge Garcia
Message 19 of 22
Love this new feature, it already makes routing easier and feels fairly natural.
Although on more complex boards if your hand slips it tends to cause eagle to crash.
Message 20 of 22
Hi Frazer2.Barnes,
Thank you for participating. Could you elaborate on the crash you are seeing? What operations cause this to happen?
Let me know if there's anything I can do for you.
Best Regards,
Jorge Garcia
