Hi
I download and install Eagle without problems. However, I can not run for the first time the software
Solved by stin93r. Go to Solution.
Solved by jorge_garcia2. Go to Solution.
note: Windows 10 with other Autodesk software installed....v7.7 is working
Me too -- exactly the same problem. Blank window frame, "Not Responding", have to kill it.
7.7 works fine for me also.
Win10.
my system is:
Lenovo y50
Intel I7 16gb ram Nvidia 960m
win 10
McAfee antivirus
Autodesk Inventor 2017
Autodesk Recap Pro
Office 2016
if you need any log please let me know.
I just wanted to offer some generic advice in this thread in case it helps.
Anyone who is experiencing this issue:
Have you tried temporarily disabling anti-virus software?
Another option may be to add a specific exception in the settings for your anti-virus software for eagle.exe.
Instructions would looks something roughly like
1. Type “VirusScan Console” at the Start screen and press “Enter.”
2. Right-click “On-Access Scanner” listed in the left window pane and select “Properties.”
3. Click “All Processes, Detection, Exclusions” and select the “Exclusions” tab.
4. Click the “Add” button, click “Browse” and select the folder or file you want to add as an exception. (%program files%\autodesk\autodesk Eagle X.X\Eagle.exe - this is a bit of a guess sorry if it is not exact)
5. Click “OK” in the “Add Exclusions Item” dialog box and click “OK” in the “Set Exclusions” prompt.
6. Click “Apply” in the “On-Demand Scan Properties” window and click “OK” to save your settings.
If you are running on Windows another tip may be to right click on the launch icon for Eagle and select Run As Administrator.
I hope this helps!
I am having the same issue
Intel i7 4790K
2 x Nvidia GTX 770
Windows 10
Office 2016
Fusion 360
Avast Antivirus
I have tried the following:
Run Eagle 8 as administrator
Disable antivirus
Disable windows firewall
Running GPU with and without SLI enabled
None of the above steps worked. The application starts to open, checks internet connection and gives the Stopped Working error when attempting to open the login window
no, no working
I remove completely the antivirus
Reinstall
and run as administrator.
Another detail is that my default explorer is not IE or edge. This looks similar to a bug of inventor year ago where it crashes before opening the license menu and it was something with net framework. If you don't find a solution I am willing to give you monitored access to debug this on my laptop.
That's the problem. Apparently not only can it not handle non-ASCII characters, but perhaps not spaces in filenames either.
Ah, I miss the old MS-DOS days...!
thanks,
-eric
I'm still having this trouble. Eagle is installed to default 'C:\Eagle 8.0'
I have tried uninstalling and reinstalling it. Re-downloaded and installed to default. Uninstalled and installed to 'C:\Eagle8.0' to remove the space.
Me too I installed in C:/Eagle/ and not solution. How do you launch a product that can not be setup in a specific folder?
I am attaching the crash report....
I have de same problem in Win10. Message : "Eagle a cessé de fonctionner ....".
Eagle version 7.7 work correctly !
Hi Wargo, denis and others,
Let's explore a few other possibilities. Is anyone under any IT restrictions? Corporate Firewall or in any other way limited. If you have special characters in your name (accents, apostrophes, etc.) please adjust your account to not have them.
If you are behind a corporate firewall, then you will likely need a proxy in order to use EAGLE. Our next release will have the proxy functionality enabled to solve the issues for those with IT restrictions.
If neither of these scenarios apply please post again and we'll continue to work through them.
Please accept as solution if my post fully resolves or you issue, or reply with additional details if the problem persists.
Best Regards,
I am behind institute proxy. Port 80 and 443 are open.
Waiting for the next build to come.
thanks a lot Jorge
I am on a home network. I can try putting my system in a DMZ later tonight and see if that resolves the issue.
MY user is "xxx xxx" with a space between as is a Microsoft account. I am in home network without a corporate firewall. is the space affecting the launch?
