EAGLE Forum
Welcome to Autodesk’s EAGLE Forums. Share your knowledge, ask questions, and explore popular EAGLE topics.
Eagle 8.0.1 "We’re experiencing some problems accessing your Autodesk account."
19 REPLIES 19
Message 1 of 20
FrankEagle
3902 Views, 19 Replies
I've a problem with Eagle 8.0.1,  launch keeps on failing on Mac OS X Yosemite 10.10.5  due to "...some problems with my Autodesk account".
I purchased a 1-month standard license for Eagle 8 and used it correctly with Eagle 8.0.0 .
On my computer Eagle 8.0.0 and 7.7.0  are still installed.
Attached is the error window.
Thank you.
Tags (1)
19 REPLIES 19
Message 2 of 20
jorge_garcia2
in reply to: FrankEagle
Hello Frank,
I hope you're doing well. Have you tried again since?
I just tried 8.0.1 on my Mac with 10.12.3 and the service is running. Is there anything special about your internet connection? Do you have to go through a proxy?
Please let me know and we will try our best to get to the root of the problem.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
Message 3 of 20
FrankEagle
in reply to: jorge_garcia2
Hello Jorge,
My internet connection is working and has no proxy. I also tried from a different LAN, with the same result.
I was thinking...I never set my account credentials on the last downloaded version, 8.0.1.
Should I? How?
Thank you for your help.
Best regards,
Francesco
Tags (1)
Message 4 of 20
jorge_garcia2
Hello Francesco,
You should setup your account credentials. If EAGLE didn't ask for them then that would indicate a problem. If you can get to the EAGLE control panel then go File > Sign Out and that should clear the licensing info that has been cached.
If you can't sign out. Then you can manually delete them and then start EAGLE again and it should ask you for your credentials. The file is:
~/Library/Preferences/com.autodesk.EAGLE\ 8.0.1.plist
Go ahead and delete it. After you have deleted it run the following command in a Terminal:
killall -u $USER cfprefsd
Please accept as solution if this solves your issue. If not please reply and we'll look into it.
Best Regards,
Jorge Garcia
Message 5 of 20
FrankEagle
Yes it worked.
1. I signed out on Eagle 8.00
2. I started Eagle 8.0.1 and it asked me for credentials, then it started correctly
Thank you Jorge.
Best regards,
Francesco
Message 6 of 20
DanCH8544
same problem with me, but with Eagle 8.0.2. It worked fine until yesterday. This morning I could not login. The 'Continue' button didn't work. Yes, we did pay the license.
I was unable to apply the solution proposed earlier in this post. I could not even find the *.plist file, neither could I find its directory.
Any help?
Daniel
Message 7 of 20
jorge_garcia2
in reply to: DanCH8544
Hi Daniel,
The servers were out for part of yesterday. Could you try again today?
Let me know if you continue to run into problems.
Best Regards,
Jorge Garcia
Message 8 of 20
DanCH8544
Hi Jorge,
still not working this morning. We also got an e-mail from your Customer Support, telling us that they reset our password. Still not working.
Frankly, if the Software that WE bought, doesn't work because YOUR servers are down, then you have a serious problem. I am an EGALE user for more than 20 years. What is going on now is disappointing.
Daniel
Message 9 of 20
jorge_garcia2
Hello @DanCH8544,
I hope you're doing well today. It would seem then that something else is at play here.
I haven't seen you mention what operating system you are on, however if you are on Windows, then you have to look else where it's actually in the Windows Registry.
Try clicking on your start menu and type regedit followed by enter. You'll find you current license under:
HKEY_CURRENT_USER > Software > Autodesk
Find your current eagle version and clear the subscription information.
Now start EAGLE up again and log in again. Does it work?
Best Regards,
Jorge Garcia
Message 10 of 20
DanCH8544
Hello Jorge
I removed the 'subscription' from the EAGLE 8.0.2 folder in the registry. That didn't make any difference. Still can't login. I will send you a private mail with a print screen of the registry. So you may look whether there is something wrong with it.
Daniel
Message 11 of 20
jorge_garcia2
Hi Daniel,
I saw the screenshot and it still showed the licensing info so I assumed that you hadn't deleted it yet. When you delete it and login again does EAGLE work now?
Make sure to delete all of the subscriptions if you have multiple installs of EAGLE on the machine.
Best Regards,
Jorge Garcia
Message 12 of 20
msb71348
I have the same problem: When I want start EAGLE, I only get this message:
Oops… an error occurred
Please try again later.
Since 2 weeks Smiley Sad I've tried to delete the KEY in the Registry, didn't helped. Anything else I can wipe out? Of course I've tried install new, start new, all the basic troubleshooting stuff.. Switching Firewall and MS Defender off doesn't matter too.
System is Windows 10 Enterprise LTSB. An EAGLE 7.7.0 is on my Computer as well.
Message 13 of 20
DanCH8544
in reply to: msb71348
Hello msbxxxxx
Deleting the registry didn't do the job for me neither. The support guys from Eagle at Autodesk are currently looking at my case. I guess they will provide information at this thread as soon as possible.
Daniel
Message 14 of 20
msb71348
I'm realy keen on getting a solution for this problem. I need my EAGLE as soon as possible Robot Frustrated
Message 15 of 20
DanCH8544
They are at it. Apparently they did something on their (server) side. But still no solution for me. How about you. Solved the problem?
Daniel
Message 16 of 20
matt.berggren
Sorry guys, have you tried uninstalling and reinstalling EAGLE?  Also, do you use a proxy?  We made changes server-side several weeks ago but fixed the issue a handful of users were experiencing related to this, within 6 hours.  There shouldn't be any issues with accessing the license server or the software.
Can you check the accounts.autodesk.com page and let me know whether you can access that page also?  If so, can you try installing 8.1 and see if that fixes the issue you're having?
Best regards
Matt
Message 17 of 20
msb71348
in reply to: matt.berggren
I tried:
- EAGLE 8.1, uninstall, reinstall, a few times...
- different internet connections
I can logon on to accounts.autodesk.com.
While installing / opening EAGLE, I'm never asked to sign in. EAGLE seems to know my account, even after reinstalling and deleting the key in the registry.
Message 18 of 20
edwin.robledo
Hi msb71348,
Please close any libraries, board, schematic or CAM Job you might have open.  From the EAGLE control panel click on File/Sign Out.  Please let me know if  you are able to sign back in with your Autodesk Credentials.
Best Regards,
Ed
Edwin Robledo
Tech Marketing Manager
Message 19 of 20
Hello at all in this thread,
I wanted to share some more information here how we got it working for DanCH8. I don't know what finally solved the problem, but maybe it helps on another system as well.
- First we deleted the Autodesk EAGLE registry entries at  HKEY_CURRENT_USER\Software\Autodesk\EAGLE 8.x.x\subscription
- We renamed the user-specific config file eaglerc.usr which usually is in c:\Users\your...name\AppData\Roaming\CadSoft\EAGLE so
  that it is not affecting the program start
- Next we tried to start eagle.exe (did not work)
- Now I tried to start eaglecon.exe. ---  and it worked!! We could log in to the account and it is running.
- Quit eaglecon.exe  and start eagle.exe again. It's working!!
eaglecon.exe was started by double clicking on it from the Windows Explorer. It is at the same location as the EAGLE program file.
I hope this helps.
Best regards,
Richard Hammerl
Message 20 of 20
msb71348
in reply to: RichardHammerl
I was not able to log out because I was not even able to start EAGLE.
But
@richard.hammerl wrote:
- - Now I tried to start eaglecon.exe. ---  and it worked!! We could log in to the account and it is running.
solved the problem. I was able to log on again and now everything is running fine again.
Thanks a lot!
