Strange one. I created my own resistor library, importing a symbol from a working library. I went ahead and created my package, then device, etc. I have a device with a symbol, package, connections and prefix as I understand from the video series. But when I place the symbol on the schematic, it i the value (R1206), not a blank value. I go to the properties, and there is no value field to modify. Just device and package - both of which are named R1206. Name shows correctly - R1, position in the schematic, Gate G$1, what library it is from. It is smashed. I bring it a part from another library - resistor-power supplied by Eagle, and I get the same thing except there is a value field and some attributes. What is going wrong here? I really need to enter resistor values.
Solved by jorge_garcia2. Go to Solution.
hello,
I have been having the same issue. I have a schematic with lots of custom parts. On some of them the value is not showing up. The radio button is definitely set to on. As far as I can tell, all of the other parameters are the same between the parts with values showing up, and the parts with values NOT showing up. any suggestions?
Thank you! the re position tool worked. I chose the re position tool, and then just clicked on components that were missing their values.
