Could someone explain the difference between these two quick route methods? What help says isn't very helpful since both mention that you need an airwire and you can select existing wire, pad, or via. Other than the route airwire not working with differential pairs I can't tell the difference.
In practice, I've seen situations where one will work and the other won't. But that hasn't seemed to follow any pattern I can detect.
Quick Route Airwire (SET ROUTE_MODE QUICK_ROUTE_AIRWIRE)
In Quick Route Airwire mode, you select individual airwires that you wish to be automatically routed, and the ROUTE command instantly routes them. You can also select an existing wire, pad, or via in the design, and if the command can determine an unambiguous nearby airwire then it will route that.
Quick Route Signal (SET ROUTE_MODE QUICK_ROUTE_SIGNAL)
In Quick Route Signal mode, you select any signal object (airwire, wire, pad, or via), and the ROUTE command instantly routes all airwires that are members of that signal. When the signal that you have selected is one side of a differential pair, then the command automatically routes both differential pair signals together. If no airwires are found, then the ROUTE command displays an error message.
Solved by jorge_garcia2. Go to Solution.
That makes sense. Perhaps adding a bit of that to the help file would be useful.
Thanks a million,
James.
