Difference between hierarchal schematics and desing blocks
b.wydrych95
b.wydrych95
what is the difference between hierarchal schematics (available in premium subscription) and modular design blocks? It looks similar to me. I'm considering subscription, but I didn't find precise description of hierarchical schematics. Thanks for your help.
edpataky
Hierarchical schematics allow you to look at your design from a system level view, integration of components, etc .. For example, a hierarchical top level schematic might be a watch design, composed of several other blocks (microprocessor, sensors, display, memory, bluetooth, etc).  The top level hierarchical schematic page allows you to see those blocks and their interconnections and to traverse down into them for the particular, individual designs.
Design blocks are reusable schematic and layout components, that you can transfer to different designs.  For example, you can very carefully make a schematic and layout for a voltage regulator, or bluetooth circuit with IC and antenna interface, (or whatever you need for your design), and you can save this block of schematic plus layout as a design block.  Then, in any number of other designs, you can easily insert the design block (schematic, and layout) and not have to redo that portion of the design.  Note you can find many design blocks available for use when you install EAGLE, and you can easily make your own.
Also note that hierarchical schematics (or non-hierarchical schematics) can contain and make use of design blocks.
Does this makes sense?
edpataky
here you see a top level schematic in a hierarchical design .. the individual modules have their own set of sheets, which you can drill down into and edit / view .. this is a hierarchical design and it allows you to abstract some portions of the design as separate "modules" which encapsulate 1 or more sheets of schematic.
Hi, can you post a link to a tutorial on creating and using hierarchical modules.
edpataky
The only one I know of is this one, for that particular topic, but it is very outdated .. the same general commands and operations apply although the interface in the video is very old
https://www.youtube.com/watch?v=1J6UeNAEJQA
I would note that this feature will be redesigned in a future version of the application
