- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I need to make many small traces around 0.4mm, setting each manually is not an option.
If I click icon to draw air wire (trace) -> then on upper tool bar, set the drop down from 0.4572 to 0.2, you would think it is set. However, when I go to draw the trace, I click on air wire again and draw the trace but it comes back as 0.4572 each time
I tried command "set width 0.3". Each time I do airwire, it still defaults to 0.4572
However, If i do "set width 3", this works and the new default value is a huge trace
I know the values I am setting are valid as I can change existing traces down to 0.1mm
Ive tried net classes, changing the default to 0.4 but no luck either.
help is appreciated. Thanks Jorge
