Announcements
Cutouts shapes in tStop layer
gavin.uberti
gavin.uberti
In the top layer, I have some intricate copper designs made by taking a polygon and making many (30ish) polygon cutouts (see below image). Now, I'd like to use the tStop layer to expose all this copper. However, the tStop layer does not seem to support polygon cutouts. Is there a good workaround for exposing these copper designs?
Thanks in advance!
mtl_asm
just to clarify, you want just the interior regions exposed? or the outline as well?
unfortunately only signal layers support "rank" so that is likely why your technique is not working with tstop layer
Rank
Defines how polygons are subtracted from each other. Polygons with a lower 'rank' appear "first" and thus get subtracted from polygons with a higher 'rank'.
Valid ranks are
1..6. Polygons with the same rank are checked against each other by the Design Rule Check. The rank parameter only has a meaning for polygons in signal layers (1..16) drawn in a board and will be ignored for any other polygons. The default is 1."
But what you could do to work around this is put some ranked  polygons on an unused signal layer, then in the CAM processor put that signal layer on the soldermask gerber file instead. (and obviously not on any of the copper layer
files in  the gerber).
There might be another solution but im not that familiar with polygon cutouts/rank etc
gavin.uberti
I just want to expose the regions in red. I'll give that solution a shot.
