Creating a proper footprint in eagle
91220001781
91220001781
Community Visitor
Community Visitor
I use eagle to design my pcb. I need to create a component which is the relay. The relay I want to create it’s library has through hole pins. I added to library these pins in footprint but I could not assign name to them. Therefore, I am not able to connect my symbol’s pins and footprint’s pads. How can I assign name to these pins? Or If there is easy way, please show me.
jorge_garcia
Hi @91220001781 ,
The connection is done at the Device level. The device is what maps the footprint to the symbol. Make sure to create the Device and then you'll see how you can connect them.
This video covers the whole process from start to Finish. It has timestamps so you can skip to the part you are interested in.
https://www.youtube.com/watch?v=C8sEz5VfC-Y&t=49s
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
