Connecting to Module Bus Ports
I need to take Bus outputs from several copies of a module and tie them into a bus. Currently, the module has a port that is attached to a net labeled IIN[0..3], and I'm wiring it to a named section of bus that comes off the larger bus (IIN[0..3], IIN[4..7] etc). However, when I run the ERC it gives an error similar to "BUS IIN[n...n+3]  is not compatible with port IIN[0..3]".
See screenshots for example.
What do I need to do to be able to connect to Bus ports in modules?
Here is a little trimmed down example that shows the issue for two devices. Interestingly, it doesn't complain about the first device, which makes me think it might be a bug. It only complains about BOB[4..7] not being compatible with IIN[0..3], but the BOB[0..3] works fine.
So I talked with Jorge Garcia on the phone this morning about this issue. They said that this is a known bug and should be patched in a future version once they rework how modules work.
For now, the workaround is to just add ports for all nets separately and then you can merge them back into a bus at the higher level as expected. An example of this is shown below. Note that you only have to do this if the net names don't end in the same numbers so wiring port A[0..3] to bus B[0..3] will work, and wiring port A[4..7] to B[4..7] will work, but wiring port A[0..3] to bus B[4..7] does not work.
Is there a fix for this yet?  It is extremely inconvenient to break out 60+ pins from a bus on a "high-level" schematic page.
jorge_garcia
Hi @Anonymous,
I hope you're doing well. Unfortunately, this has not been addressed yet.
I don't have an ETA on when this will be changed but it still a ways out.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
sdalling
Is there any update or ETA for the new modules work that address this bug? A new design of mine has bus ports that are not convenient to break out one by one.
jorge_garcia
Hello @sdalling,
I hope you're doing well. Unfortunately, I don't have an ETA for these improvements. Hierarchy as it is now is still the same as when these posts were originally made. Fixing that system is going to be a big undertaking and there is a lot going on right now.
For now you can alleviate the pain by right clicking on bus and choosing the breakout bus option. That would allow you to get everything out in one go. We recognize the limitation and we will address it but we don't have anything else for right now.
Best Regards,
Jorge Garcia
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
