I have come across this PCB layout which has got me a bit confused over the way the components are connected here. You can see in the image of the close up there is a clock in the middle and two capacitors on either side. The capacitors should be connected to the ground, but I do not see that connection, am I missing anything? Also, is there a reason for there to be a through hole under the clock - is this to have more surface area to hold the clock to the board with solder paste?
In the large image of the circuit I have noticed a large number of through holes which dont seem to be connected to any kind of tracks. Is there a reason for that large amount of throughholes?
Dan
Solved by C.Nicks. Go to Solution.
danw5050,
There looks to be polygons that have not been processed, and that's where all of the vias will connect to ground. See the dotted outline around the outline of the board? That's an unprocessed polygon. If running ratsnest does not process the polygons, go to "Options -> Set... -> Misc" and ensure "Ratsnest processes polygons" option is checked. Also if you haven't, read the polygons section of the help to understand how Eagle handles polygons.
As for the ground via under the clock, that looks like it's there for extra ground stitching. Personally I tend to keep ground pours out from underneath crystals. Check the datasheet to see what the layout recommendations are.
Hopefully this information helps you out.
- Cameron
Best Regards,
Cameron
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
