I have a custom library where I took parts from managed libraries and edited the drill and pad sizes and used the replace function to change all the parts in a project to my custom version. This version failed the DRC for a PCB machine I am using so I went back into the library to change the footprint to have smaller pads which would fix the problems except the schematic will not update to this new version.
I've tried to make a new library and a new project but the footprint always stays the same even when I do the same thing I did to replace them the first time even though the correct footprint shows in the library viewer.
The screenshots show the correct footprint with most pads being small in the library (the new version that I want to use) and the part on the board which has all large pads (the version I want to replace and that was edited from a different version previously)
