Changing the color of the Soldermask
Mschindl
Mschindl
When I push my board from Eagle to Fusion 360 the solder mask always comes out green with white silkscreen and copper colored copper traces. This is applied as a decal over the board in the fusion model.
I was wondering how to change some of the colors of the board like solder mask and copper traces. I would like to make the solder mask black and the copper traces a little lighter than the solder mask so you can still see them but they look cleaner. Is there a way to do this?
I've the same problem with the same question....Did you manage to solve it ?
jorge_garcia
Hi Guys,
I hope you're doing well. I've reached out to the devs on this, at this point we don't have a solution for altering the colors of the decal. The request will be noted so keep your eyes open.
Please let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
To anyone interested, follow this tutorial, that's perfect to export the PCB image and change it the way you like in Photoshop:
http://www.madwizard.org/electronics/articles/pcbimage
Greetings 😄
stanislawZPPTC
Did you add option to change soldermask color?
