Change numbers on a toggle switch ???
keld.soerensens
keld.soerensens
I just updated from an old version to the Autodesk Eagle 9.2.0 and a lot have changed !
I have added a toggle switch to my schematic and wants to change the numbers on the pins !!!!!!!!!!!!!!!
I think I did it in the old version by clicking a butten "SMASH" and then I could select/change every pin.
How is it done in the 9.2.0 version ?
Best regards
Keld Sørensen
Denmark
havlicek6TH3H
smash worked only on names and values.
Number of pins are bounded to footprint pins so you can´t change them without editing library.
If you want to change the visibility of pin number you have to do it in symbol (library edit).
  1. Go to symbol
  2. Right click on pin
  3. Select properties
  4. In 'Visible' you choose what you want
  5. Click OK and save
Best regards,
Vojta
keld.soerensens
I think I did that MANY times i the old version ... ?????
Anyway ... I don't get you ... your list don't get me anywhere !
  1. Go to symbol                - I click on the toggle in my schematic ????
  2. Right click on pin        - ???????? can't select a pin
Best regards
Keld Sørensen
Denmark
havlicek6TH3H
You have to edit library as I mentioned...
PS: I would ask you to add more question marks and exclamation marks :))) It would be awesome
