change all wires width ? how to
Hello i want to change all my wire width  on same time not wire by wire , can someone show me how ?
  thx
didrik.madheden
By using the group (selection) tool, select all items you want to change. OR press ctrl+A on your keyboard to select everything.
Click the change tool (looks like wrench) and select the width menu followed by the width you want to change to, or the bottom ".." value to enter your own precise value. The same of course works for changing any other setting that you see in the menu.
Hold ctrl and right click in the work area to apply the new width setting to the selection.
I'm a regular forum user, and not affiliated with Autodesk, but I like contributing to the forums to learn new things about Eagle. If this post answered your question, feel free to mark it as a solution. If something needs clarification, feel free to ask.
jorge_garcia
Hi @Anonymous,
I hope you're doing well. @didrik.madheden posted the right solution. I just wanted to add that if you have Group Default mode On (It's the default setting so it's likely that you have it on), you must do that ctrl+right click on a component that is a member of the group.
Small difference but I thought I should note it just in case.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
thx the solution is working ...thanks you
