Cannot push or pull board!
shaische222
shaische222
I've had this issue before on occasion but at this point it's absolutely frustrating especially since I pay for Eagle. This is a PCB design in Eagle that I've worked on since before Autodesk incorporated Eagle into Fusion. After Autodesk incorporated eagle into fusion and created new file formats inside fusion for a schematic, pcb, 3D pcbs, etc... I've had issues when moving components inside Eagle (I still only use Eagle standalone - don't use the one in Fusion). Whenever I move components, duplicate drill holes remain in the original location and I'm unable to delete it even when on the dimension layer and they show up in the preview.
But the real reason for this thread is that my board now cannot push or pull into fusion and vise versa. I've cleared my fusion cache and restarted yet and signed-in again into Eagle standalone and also re-linked the file in Eagle. Nothing helps. It now shows in Fusion file not available.. I've tried to push earlier versions up in Fusion of the file, nothing helps. I'm out of ideas at this point. Please provide a solution both to the drill holes issue and push/pull.
shaische222
Can anyone from Autodesk help with this?
jorge_garcia
Hi @shaische222 ,
I hope you're doing well. Would you be willing to share the files for our devs to analyze. I'll send you my e-mail through DM.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
