Hi All,
When I switched to 9.3.0, I immediately had problems switching layers while routing differential pairs. Pressing the center mouse button no longer changes layers (still doesn't). As I experimented, I discovered that selecting a different layer from the drop-down menu did still work and got me through the hump. The original case is here: https://forums.autodesk.com/t5/eagle-forum/9-3-0-can-no-longer-change-layers-while-routing-diff-pair... At the same time, clicking the center mouse button did change layers normally for normal (single-ended) traces.
Today I have started a simple new 2-layer board and cannot route it because I cannot change layers using any method (center mouse button, pull-down, even the layer command). It looks like Eagle is trying to change layers showing me a visual prompt (there's a small orange circle around the trace being routed), but clicking or dragging never shows a trace on the bottom side. Dragging makes Eagle behave as if it is trying to miss obstacles on the top layer.
If I select the bottom layer (16) and drag from a through-hole component pin, the trace does route on the bottom layer, but I cannot change to the top-side. Interestingly enough, the auto router can switch layers and route on both sides.
Needless to say, I'm dead in the water trying to get this board routed.
Thanks for your help,
Scott
