Announcements
CAM drawing file, how to attach
In the CAM window I want to attach a drawing file explaining a routed slot.
How do I attach it and what format should it be for a Fab to use it?
Does it get compiled with the Gerber file output?
Thanks.
jorge_garcia
Hello @Anonymous,
I hope you're doing well. That setup is to generate geber data you can't attach anything to it. You can produce a fab drawing gerber by creating a new section under the gerbers and then specifying what layers form that drawing.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
