Button PCB part
Button PCB part
Button PCB part
Hi I'm trying to make a common ground button PCB and am struggeling to get a button pad thingy (see picture)
From what I've understood, I need to put it into the schematic before adding it to the board. How do I go about adding new components? Any tutorials?
Thanks in advance!
rachaelATWH4
Thanks in advance!
Hi Frederik,
I'm writing a tutorial series for creating library parts in EAGLE and publishing it over on Element14. It'll be an 11 part series when complete, the first 5 parts are published. These should cover most of what you need to know to get going with creating your own parts and help you create the part you require here though.
The first part of the tutorial can be found here: EAGLE Tutorial: Library Part Creation Part 1 - Creating Packages
Best Regards,
Rachael
Hi Rachael!
Thanks for the great tutorials! Did the trick for me!
Keep up the good work! 🙂
Frederik
rachaelATWH4
Thanks Frederik Smiley Happy
I'm glad to hear you've now got it sorted!
Best Regards,
Rachael
