BC547
BC547
simonmunyua6
Message 1 of 10
BC547
simonmunyua6
Hello all, am using the BC547 transistor in my project and after finishing the design and trying to make some order of the PCB, I have realized that the BC547 is not available with my manufacturer and therefore i have to replace it with another transistor equivalent. Please advice me on which transistor is best fit to replace this one.
Replies (9)
Message 2 of 10
CGBenner
@simonmunyua6
Which Autodesk product are you working in?
Chris Benner
Message 3 of 10
simonmunyua6
Am working with Autodesk EAGLE for electronic PCB designs and i have not seen an option for component alternatives when you are given one component and maybe it is not available in the market
Message 4 of 10
RobDraw
Isn't there a forum for that program?
Rob
Message 5 of 10
simonmunyua6
I have read about the BC548 here Introduction to BC548 - The Engineering Projects and i feel like it is the equivalent transistor to the BC547 that i have been looking for. Can someone help to confirm if am in the right direction before I use this type of transistor?
Message 6 of 10
one-of-the-robs
This really isn't an Eagle question - you'd be better with a general electronics discussion forum.
However, the BC548 is pretty similar to the BC547 and will probably be an acceptable alternative.
Message 7 of 10
simonmunyua6
Can I get the BC548  data sheet? I think the data sheet will help me a lot. Thank you!
Message 8 of 10
one-of-the-robs
THIS IS NOT A GENERAL ELECTRONICS FORUM
NEITHER IS IT A SUPPLIER WEBSITE
USE GOOGLE
Message 9 of 10
simonmunyua6
thanks for the guidance. The BC547 just worked so well for my design. I replaced the BC547 with the BC548 and the end results are perfect. It is the best match .
Message 10 of 10
7736629
Community Visitor
Community Visitor
If you're looking to replace the BC547 transistor in your design, a good equivalent option would be the BC548, which is quite similar in terms of electrical characteristics and usage. The BC548 has the same general specifications and can work well in low-power amplification and switching applications. Both are NPN transistors, with similar voltage and current ratings.
You can find the BC548 transistor for your project on Xecor, an online distributor of electronic components.
Make sure to verify your design's current and voltage requirements to ensure compatibility with the replacement transistor.
Good luck with your project!
