I am building a 90V plate voltage supply for an old tube radio using ten 9V batteries in series (yes it will work and it will work for a long time). I found a PCB component in Eagle, that came with Eagle, that is supposed to be for a 9V battery clip, AB9V. It is found in the supplied library called Battery. However the footprint is not right. size.
(1) I paid for the standard subscription service. I am not an early convert. I recently decided to give the paid service a try and so far... it isn't going very well, but it's early. I think it's not out of the question to expect the library that comes with this software to be accurate. This is the second, seemingly simple project, that I've done and I already have to fix a component.
(2) This is the datasheet for an actual component that works- https://www.mouser.com/datasheet/2/215/68-741068.pdf
The center to center dimension for the posts is 0.5". That matches a real battery. The center to center dimension for the component in Eagle is 0.2" and it doesn't match a 9V battery.
(3) Is there a quality control department at Autodesk?
