Aspect ratio setting
kshirsagar564
kshirsagar564
Hello everyone!
I have following questions for you:-
1) I am getting a DRC error "Blind via ratio". I have attached the layer stack up for your reference. My manufacturer says thickness to diameter ratio <=8. To remove this error what should i write in the DRC->sizes-> min blind via ratio. Currently it is set to 0.5 by default.
2) I have a very dense PCB with space constraints. I have to connect lot of smd signals from top to bottom. Can you suggest a 6 layer stack up equation (with blind, microvias and buried vias) that you have already completed successfully as HDI?
My board size :- 80x80mm
components :-700(containing 0805, 1206,2512 smd packages)
test points:- 50
kshirsagar564
@kshirsagar564 wrote:
Hello everyone!
I came across the capability section for one of the manufacturer. It mentioned thickness/diameter ratio as 8 i.e 1:8. So I put 8 in the  DRC->sizes-> min blind via ratio and issue was solved!!!
