Altium library Import problems
I am new to Fusion and Eagle enjoying the software and am in the process of migrating from Altium Designer. I am using the Library.io to convert Altium part librarys with mixed success. I have had success with 3 out of 5 imports so far. Of the 2 that I am having trouble with:
First one is a .IntLib which I was able to upload, however it is stuck at 0% in the processing window for almost 24hrs. Since it is not complete with the conversion I have no obvious way to cancel and delete the file. Ultimately a small problem but it really bugs me to have it stuck there.
2)I converted a .SchLib and when I view it from Library.io has 293 components 300 symbols, 359 packages and 359 footprints. When I try to edit it in fusion it says it has 0 of everything. If I try to import apart from it into a custom library I am creating in Fusion it will show me the list of parts that are supposed to be in the library but the view windows are all blank and when I actually try to import a device fusion crashes. If I try to import a footprint or symbol, nothing happens but it doesn't crash. I feel like I probably have something wonky with my original lib but it works fine in Altium, any suggestions as to what to look for would be much appreciated. Also are there any offline library scrubbers/converters?
Thanks to all in advance!
