Add space character using the value command
I'm trying to make an easy script to change the values of multiple parts. But I can't add space in my values when I use the VALUE command.
For example, when I set the value of R1 using the VALUE button(or right click and Value) from the tool bar, I can write "10k 5%". However, when I use the type "Value R1 10k 5%" in the command line, the part value only shows up as "10k". All the words after the space is deleted.
Is there a special character that I have to write instead of just adding space? I searched everywhere, but I couldn't find anything.
I don't want to click every single parts and change the values.😫
If the command doesn't work, is there a script or ULP that I can use?
Thank you
one-of-the-robs
Have you tried quoting it?
value R1 '10k 5%'
It works!
never thought of quoting the whole thing.
Thank you so much!!!!
