3D Model Generation has failed
Message 1 of 13
I have previously generated STEP files for this board, all I have done is move a few components and add traces/vias, no components have been added. I get a failure instantly every time I try to generate a STEP file. What could be causing this, it gives me no additional information on why it failed to generate a model.
Replies (12)
Message 2 of 13
jorge_garcia
Hi @Anonymous,
This is hard, it's possible your design was on the edge of timing out the servers. Another possibility would be some part that isn't handled by the conversion. The only way to know would be to inspect the file. I'll send you a DM with my e-mail so you can send the file for review.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Message 3 of 13
purchasingSMLXL
Community Visitor
Community Visitor
Just had the exact same thing happen to me.  What is the fix?
Message 4 of 13
jorge_garcia
Hi @purchasingSMLXL,
I hope you're doing well. Try it again and if it fails once more let me know and I'll talk to the developers about it.
Best Regards,
Jorge Garcia
Message 5 of 13
farzad.vaziri
Observer
Observer
I have the same problem, I need the step file today, what should I do?
i tried so many Times
Message 6 of 13
farzad.vaziri
Observer
Observer
Log in /Log out from Eagle and restarting Windows did nothing.
Message 7 of 13
juanrendonXRJ3G
Community Visitor
Community Visitor
Right now I'm experiencing the same issue while exporting the .brd file to a .STEP
I've exported this same file some time ago but now it continues throwing the same error.
Here is a snip of control panel home tab:
Does anyone knows how to solve it,
Or at least what's the reason for this?
Message 8 of 13
igorFZMQ2
Community Visitor
Community Visitor
I am experiencing the same issue. I think the source is timing on servers. There is probably some time limit for processing the file. When I remove any component with a complex 3D model from the board then the export of step-model succeeds.
Message 9 of 13
bootandwork
Observer
Observer
I had the same problem and I finally export to fusion360
Message 10 of 13
farzad.vaziri
Observer
Observer
can you tell us how?
Message 11 of 13
bootandwork
Observer
Observer
I have installed FUSION 360 on Eagle and I export it to the cloud.
Choose 'Create new Fusion 360 design' option and select 'Next>' button.
Then you acces to your private cloud and get the 3D Model.
Message 12 of 13
brian.bofill7YL6S
This approached worked for me too. I just needed to learn a few basics of Fusion 360,  it the advice nailed it. Just select the Fusion 360 tab within eagle and rest is straightforward.
Message 13 of 13
niklas76
I recently have the same problem!
Is there any news besides the mentioned work-around?
