VIA Problem
03:45 PM
Hello all,
This may be a simple question, however when I go to place a via in my PCB (to get from top layer VCC to bottom layer ground), and I attempt to connect a signal from a GND pin on a surface mount part to the via to connect said pin to GND, it instead tries to route to a existing connection that I have laid out on the board and does not let me connect the signal to the via. What needs to be done to fix this?
Thank You
