Greetings, all. By way of introduction, I'm a lifelong electronic tech; recently retired engineering lab technician. I've soldered, populated, reworked, and troubleshot both through-hole and SMD boards, as well as point-to-point vacuum tubes chassis, so I'm no newbie to electronics. But, having said that, I am an absolute newbie to PCB layout software; completely clueless in many ways, so please don't be afraid of insulting me in that regard! I will have many questions in the near future, many of them probably humorous, or even absolutely hilarious, to those of you who know their way around Eagle.
First question: I've successfully created my own user libraries, and placed them in the folder which Eagle created on installation: C:/documents/Eagle/libaries. I've learned how to go into those libraries and do the right-click/check "use" thing, after which those libraries now appear in the default library which appears when I click the "part" icon. But, when I exit Eagle, and then return later on, those libraries are no longer visible in the default library, and I've got to repeat the whole process to make them visible again. I've got no doubt that I'm making an absurdly simple newbie mistake here, but what is it? Running Windows 11, by the way, if that's relevant.
Thanks -
