I use eagle at 2 different locations. I believe I need a subscription for each location. The license manager will only allow me to enter myself once. What do I do?
Another problem is that it won't deal properly with my companies proxy. All the how to's say that you need to set up the proxy in IE. I'm on Linux and use firefox. So it appears that after 14 days, it will stop allowing me full access. I am using desktops at both locations, and don't want to haul them around. What do I do?
When I try and use the chat support, it always starts out saying someone is available. When I enter my info and subject, it tries to connect for awhile and then tells me no one is available. What do I do?
When I try the email support, I fill in all the blanks, including my issue. It won't allow me to put in anything for the version even though it is marked as required. When I click submit, it doesn't allow it to go because I didn't fill in the version. What do I do?
Thanks for your attention to these issues.
