inverted cam output
inverted cam output
inverted cam output
i used to use eagle since years but the new versions from 8.6 i think all have a very bad update makes me stop using this  new versions with their helpful features
this bad update was the new cam processor that didn't contain the lovely old version inverted output (ps inverted)
so i need  help with getting inverted output from newer versions or a way or another program to invert the non inverted output of these versions
thanks for all you did for us
jorge_garcia
Hi @Anonymous,
I hope you're doing well. You can still run the old cam job that you used to use to get the PS inverted output. When you load the old cam job just make sure to not update it on the left side of the CAM processor. Leave everything under Legacy and run it as is.
We are working to restore inverted output to the CAM processor. Just bear with us.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
yes i could do it and finally  my problem solved due to your effort
thanks you so much
keep forward
