I can't access a pin for an boost-buck converter because is in the middle of the part
BernyZa897UH37
BernyZa897UH37
Community Visitor
Community Visitor
I'm trying to route an the only airwire left but the other pins in the part prevent me to access the pin even if I try to go the bottom layer I can't access it because I don't have a way to come out. Is there another way to access this pin?
one-of-the-robs
Your board layout as a whole gives the impression of a fairly low-spec fab - two layer with 10mil traces and 0.6mm minimum drill? If so, that's not suitable for a high density BGA part like that. Can you not get the chip in SSOP/SOIC or similar? BGA is generally a pain and to be avoided unless you really need the high density (and are designing a ten-layer PC motherboard or the like)
