Frustration with visible EAGLE SCH Component properties
When I place a component in the schematic, I choose the device which includes selecting the footprint.
If I select the component on the schematic, I can right-click and see these parameters:
Name, Value, and also Device, Package, Library, Gate, Angle, Position.
Why can I only use >Name and >Value as visible parameters in the schematic?
Why can't I use these as visible parameters: Device, Package, Library, Gate, Angle, Position ?
I could add an attribute to the component and edit the field to say "R0402" or "SO-14",
but using the actual design (SCH &PCB) database makes more sense.
When will Autodesk make this needed change?
