Message 1 of 19
Drawing a regular polygon board edge
EAGLE Forum:
I would like to draw a regular octagon as a board edge, but I cannot seem to put together the drawing tools in Eagle that will allow me to do this, short of doing trigonometry on paper to determine the end points of each segment. I have tried drawing a construction line and repeating this in a rotational pattern, but I can't seem to make a pattern of a line in which the point of rotation is the end point of the construction line. It also doesn't seem possible to simply draw a line and rotate it through 45 degrees, or I can't find the way to do it.
Eagle's drawing tools seem rather...primitive? Is the expectation that more complex geometry would be drawn in Fusion360 or AutoCAD?
