Default Trace Width Behavior
sdalling
sdalling
The default trace width comes from one of two location from my understanding, either the net setting or from the DRC file.
For some of my designs I use net class to define he minimum size for a net that will carry current. These signals also happen to have a branch on the net that will not carry current, either a voltage sense or led and these can use a smaller trace. I have found that in Eagle if I manually set the trace width smaller while routing that it will default to the larger of the net size in either net class or DRC. is there no way design removing the net label to force a net to be smaller than what is given in the net class but larger than the DRC?
I guess is  this a bug or is this the intended behavior for net routing?
edwin.robledo
Hi sdalling,
Thank you for your participation. This is the intended behaviour, EAGLE will not allow you to use a width that will cause a DRC violation.
Ed
Edwin Robledo
Tech Marketing Manager
